Author Topic: Saving a Boston Whaler 13 from being a Flower pot !  (Read 136628 times)
Re: Saving a Boston Whaler 13 from being a Flower pot !
« Reply #90 on: June 04, 2010, 04:24:52 AM »
I had to add a Armstrong bracket to handle the New Yammi 115 hp 4-stroke motor which is 25 in.
« Last Edit: November 29, 2012, 06:03:02 AM by Cardinal Joe »
« Reply #91 on: June 06, 2010, 04:22:43 AM »
Pic's of Aquasport , hardware & trailer etc.
« Last Edit: November 29, 2012, 06:04:10 AM by Cardinal Joe »
« Reply #92 on: June 08, 2010, 05:37:38 AM »
The Deck & Hull was in Good Shape just needed a little TLC add some supports to the gunnel area and a Paint job ( fighting lady yellow ).
« Last Edit: November 29, 2012, 06:06:41 AM by Cardinal Joe »
« Reply #93 on: June 10, 2010, 03:15:47 AM »
Some finsh photo's !
« Last Edit: November 29, 2012, 06:07:06 AM by Cardinal Joe »
« Reply #94 on: June 20, 2010, 04:25:17 AM »
pic of the bow
« Last Edit: November 29, 2012, 06:07:55 AM by Cardinal Joe »
« Reply #95 on: June 21, 2010, 10:29:24 PM »
Just found my 1973 Aquasport 19.6 for Sale in fla.
 1973 19'6 Classic Aquasport for Sale REDUCED
Boat is fully restored and has 2006 F115 w/ 65 hours; new composite transom (raised to 25") and new gas tank (54 gallons). The motor was put on in November 2008 with 0 hours. It has a transferable warranty through 2014. The boat is immaculate.
Don't have many pictures since the options were added, but will take some this weekend. Some of the pictures were taken before options were added.
Includes:
2008 Karavan trailer
35 gallon Sanchez Brothers leaning post/livewell combo
24 volt Minn-Kota Riptide Trolling Motor 80 lb. w/ quick release mount
Garmin 498 GPS/depthfinder
3 new batteries with onboard battery charger
8 ft. Power-Pole Sportsman
Yamaha fuel management system w/ digital gauages
6 " Bob's jackplate
Fresh bottom paint
Recessed cleats
2 LED lights in side of console (1 on each side)
6 console rod holders (3 per side)
2 gunnel holders ( 1 per side)
Stern engine light
New engine/console/leaning post covers
Radio (CD/AM/FM)
$21,900 obo
Located in Placida, FL
« Reply #96 on: June 25, 2010, 09:17:33 PM »
1973 Aquaspoert 19.6 CC for sale in FL.
« Reply #97 on: June 29, 2010, 07:10:33 PM »
« Reply #98 on: July 12, 2010, 05:40:45 AM »
1972 Seacraft 20 Complete Restoration!!! - This Sea Craft is own by one of my restoration team worker's   we restored it over the winter .....
lonesufer - Hi everyone I am posting my winter project which I have put alot of time and pride into this winter. I already have a brand new 140 suzuki 4 stroke ready to mount once shes done. The floor was raised 2 inches to make it self bailing deck especially with the 4 stroke weight. This boat was done right all epoxy resin used no cheap stuff (polyester not waterproof) Custom console more finish work than I thought to make it look good for the awlgrip paint. I could go on and on but pictures are worth a thousand words. Enjoy!!!! Oh and I'm 22 so I'm ahead of the game I think on my boat restorations hopefully this one will last me a lifetime!!!
« Reply #99 on: July 12, 2010, 01:31:38 PM »
Cont.
deck being constructed outside of boat with raised stringers
« Last Edit: July 12, 2010, 01:38:06 PM by Cardinal Joe »
« Reply #100 on: July 15, 2010, 05:28:16 AM »
Foam free hard to find these days I hate wet water logged foam!!! Now shes light
reverse flange for mounting console to deck custom no screw
epoxy fairing putty on console All U.S. COmposites epoxy used on whole boat
« Reply #101 on: July 17, 2010, 12:38:43 AM »
New 47 gallon aluminum fuel tank installed the right way not foamed in. The tank has plenty of air around it to allow it to breath and is secured with neoprene strips supplied by SPtanks right in South Jersey. They supply tanks to all the big boys F&S boatworks being one. Fuel tanks should be foamed in as the foam traps water causing oxidation down the line.
Front hatches being recored with divinycell.
« Reply #102 on: July 17, 2010, 12:41:43 AM »
Fuel tank cover being glassed down its made of penske board (coosa board with glass on either side) Super light and strong.
« Reply #103 on: July 18, 2010, 06:37:46 PM »
Snow white awlgrip topsides and deck 4 coats
« Reply #104 on: July 21, 2010, 08:46:03 PM »
  update from lonesurfer
I got alot done in the past couple weeks. Hull is painted, console mounted, motor hung today. Armstrong hatches installed on port and starboard rear access wells. These hatches are by far the best I have ever seen very easy to install no screws and they are very tight and the most waterproof hatches you can buy. I would highly recommend these. Pop up 6" cleats in rear installed and single 8" pull up cleat installed in bow. Teak helm pod in the making my father is making this for me as he's done quite a few. ordered my rubrail today white with stainless insert.
« Last Edit: July 21, 2010, 08:48:21 PM by Cardinal Joe »
